Epic Fan Belt Squeal
Risocco
Post by Risocco »
Hi all, my 1.6 GT is being rather annoying. When I start her up, the fan belt makes a horrific noise for a good 30 seconds or so. Very embarrissing, esp when leaving work in a public car park :blush:
Noticed that the OEM volt meter gets to 12 when she first fires and takes a minute or so to reach around 14. Is this connected to the squeal? Where would I start to look for the solution, aternator or battery ect...
Fan belt is a week old, battery is a good few years old if it helps.
Any pointers greatly appreciated :hi:
Alex
wasted
Re: Epic Fan Belt Squeal
Post by wasted »
Just sounds like the alternator belt is loose. This will give the squeal and also make the alternator inefficient, which could result in the odd voltage you describe. Not hard to fix - one 7mm allen key, one 13mm socket.
Risocco
Post by Risocco »
Cheers mate, have re-tightened the belt a few times the last week, must have worked its way lose again. As long as its nothing expensive!
Alex
go-for-it1
Post by go-for-it1 »
Hi Alex, You should always re-tighten a new fan/alternator belt after about 100 miles running as they stretch. Usually after readjusting you don't need to do it again.
Rob
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
