Hi Guys,
do you know what other cars ar fitted with the same rear view mirror, my busted when I was changing the windscreen and i need a replacement
Steve
rear view mirror
- steve GT VW
Re: rear view mirror
Just the Scirocco, I believe.
I've got a spare if you want it
Out of interest, how did it break? There's a tiny Allen-headed bolt you need to unscrew to remove it from the metal plinth on the windscreen, which isn't obvious if you've never done it before.
- steve GT VW
the windscreen was cracked whist it was out I repaired the winscreen edges, the mirror was still on the old window, and was leaning against the wall when I knocked it over and it landed on tghe mirror which snapped the arm of the mirror.the edmundator wrote:Out of interest, how did it break? There's a tiny Allen-headed bolt you need to unscrew to remove it from the metal plinth on the windscreen, which isn't obvious if you've never done it before.
doh!
- steve GT VW
Hi how much do you want for it, and yes I would like it please?Mr Funk wrote:I've got a spare if you want it
Steve
I'm also looking for replacement rear view mirror 1992 scirocco GT2. The plastic casing on mine has simply disintegrated after 7 years sitting in driveway. Just got it back on road and MOTed.
Anyone out there got one?
den
den
