right then ive just fitted some G60 280mm front discs and calipers
ive also done a mk2 golf servo and 22.2mm master cylinder upgrade
bolting it all back together i notice that the brake lights are now on ????
???? why
the old master cylinder there was no electrical switch on for the brake lights and there isnt on the new one either
so where is the brake light switch
its a 1992 scirocco scala 1.8i
brake light issue
Re: brake light issue
you've either ended up with the pedal sitting slightly further down, or have knocked the switch off it's mount
