Thermostat
Bill
Thermostat
Post by Bill »
Just a Query, i'm changing the water pump on the MK1 tomorrow, could i run the car without the stat,
just thinking out loud, thinking about extra cooling and stuff. Ta :hi:
bengould
Re: Thermostat
Post by bengould »
Although yes, you can. Too much cooling won't allow the engine to warm up quickly enough. Not really recommended. You might be able to get a cooler thermostat if your really worried about temperature. But I wouldn't be unless your running a heavily tuned engine.
Ben
Re: Thermostat
look at this Bill?
http://www.ebay.co.uk/itm/220694925013? ... 1438.l2649
Wills coolant offer worth considering too - it offers lower temp benefits.
Risocco
Re: Thermostat
Post by Risocco »
These are awesome :good:
