brake pads - inner and outer
philstar
Post by philstar »
Hey guys which brake pad goes on the inside of the disc and which goes on the outside?
There is a large and a small one... can't seem to find it written down anywhere or any detailed photos!
Mk2 Scirocco 1.8 GT Rebuild Gallery: https://plus.google.com/photos/11474699 ... 0883896385
Old Mac Rocco
Re: brake pads - inner and outer
Post by Old Mac Rocco »
Page 176 Fig. 8.3 of the Haynes manual appears to show the longer / narrower one on the outside of the wheel with the shorter stubbier one on the inside.
Someone verify this please.
:bye:
philstar
Post by philstar »
That is how I have just placed them, with the thinking that the shorter fatter pad need to be against the large piston, and the longer thinner pad needs to extend to the two prongs on the outer edge of the caliper, in order to spread the pressure correctly.
I hope this is correct!
Chris M
Post by Chris M »
Longer pad on outside. Shorter pad towards the piston on brake calliper. The anti-rattle springs are fitted with the square corners to the outside.
