Red light flashing on and off in dash instruments.
G Beats
Post by G Beats »
This been happening for a little while now this red light flashing on and off. It is were the temperature gauge is in the dash instruments.Some times I switch the engine off and it goes.And after a while it goes off as well.The plastic circle that is around the ignition barrel came off I thought might be to do with ignition barrel cuss of this ? The coolant level is fine and the alternator belt is fine as well as I have checked these both.Many thanks to all those who can help.
Re: Red light flashing on and off in dash instruments.
The red flashing light shows low coolant, if the coolant in Ok then it could be the sensor or wiring to the sensor.
I have the same problem, I changed the sensor and I've still got the problem, sometimes it flashes other times it doesn't so I've just stopped looking at it now, been like it for 5 years!
Looks like this and it lives in the plastic expansion tank
http://www.gsfcarparts.com/parts/coolin ... vel-sensor
G Beats
Post by G Beats »
mark1gls wrote:The red flashing light shows low coolant, if the coolant in Ok then it could be the sensor or wiring to the sensor.
Ok great many thanks.I will check the connection as well on the of the sensor wiring.
It's probably a fault with the printed circuit board that supplies the gauge. My 82 GTI has this problem as well, I'm trying to get hold of a new set of clocks so that I can replace it. If the temp gauge needle works correctly, it's unlikely to be a problem with the sender.
the edmundator wrote: If the temp gauge needle works correctly, it's unlikely to be a problem with the sender.
On my DX engine Golf the temperature gauge works from a sensor on the front of the engine which goes to the top radiator hose, the coolant level sensor is in the expansion tank so they work of 2 different sensors.
On earlier cars (like both of my GTIs) there is no coolant level sensor, so only one sender.
I didn't know that so how does it know if the coolant is low?
I think the one in the expansion tank works from the two prongs making a circuit when the coolant is ok and when its low in the tank the circuit is broken so the light flashes, but I could be wrong.. :dunno:
mark1gls wrote:how does it know if the coolant is low?
Only by the old-fashioned method of the driver stopping the car, opening the bonnet and having a look.
The flashing light is just to let you know that, in case you hadn't noticed the needle creeping up the dial, or the steam billowing out from under your bonnet, you really ought to think about stopping... now!
G Beats
Post by G Beats »
Ok I will I tell at I have had a look at the plug on top of the coolant bottle I have unplugged it cleaned it and plugged it back in still the same problem. Next Ia'm going to clean it up with the connectors with electric connect cleaner and see if that will sort it if not will get a new plug and try that and after that looks like I will have to sort out another circuit board.And after that if it does not work ? :dunno:
G Beats
Post by G Beats »
geebeats wrote:Ok I will I tell at I have had a look at the plug on top of the coolant bottle I have unplugged it cleaned it and plugged it back in still the same problem. Next Ia'm going to clean it up with the connectors with electric connect cleaner and see if that will sort it if not will get a new plug and try that and after that looks like I will have to sort out another circuit board.And after that if it does not work ? :dunno:
Ok I have tried cleaning it up the plug with electric contact cleaner it is still flashing next Ia'm going to buy a new plug.
rustyinn
Post by rustyinn »
Did the new parts fix it ? I've got the same problem on my 1986 GTX. Starts flashing about 5/10secs after startup, coolant level is fine and is circulation. Temp gauage never gets over hot. Just damn annoying as your driving.
Dave
1970 Porsche 914-6
1973 T2 Bay Window
........ and a 1937 Austin 7 Van !
ChrisPears
Post by ChrisPears »
I used to have this, it would go off if I stopped and restarted the engine straight away. New sensor didn't fix it, never did find out what was wrong, it stopped doing it when I changed the engine, so it kind of points to a wiring issue. A loose connection or something that got fixed when I was wiring in the ECU etc.
Bit of a drastic fix for a flashy red light :hugegrin:
Thinking about it, I changed the expansion tank too, but I can't see how that would have fixed it.
I think they are suppost to flash when you 1st turn the ignition on, then flash for a few seconds. So your might be normal, mine flashes when ever it feels like...
G Beats
Post by G Beats »
No I have not brought a new plug for it yet.I have tried switching the engine on and off it stops it for a few seconds then it starts again and then carries on continuously until the engine is switched off.
roccoGTX
Post by roccoGTX »
I had this prob once in my Mk2 GTX with the temp light flashing.
I had oil going into the header tank, due to the oil cooler on top of the oil filter breaking down and mixing the oil and coolant. Also had overheating. There was no mayo under the rocker cover.
After a lot of invesigation we found the cause, but not before the oil contaminant had perished the coolant hoses.
Had to replace oil cooler, hoses, header tank and water pump and have the head skimmed as it was slightly warped.
Since then it's been fine.
I think that the oil coolers are becomin g a bit rare now.
John
