Well in the near completion of welding on my Scirocco Ts 76, I've completed the rear and only the front end to sort
but need some help and a few questions answering well here goes:
1. are early inner wings different to later inner wings as i have some NOS inner wings but part number different from the early ones?
2. my car came with rear lights one with chrome trim one without which one is correct?
3. does any know or have pictures of the radio/cassette the early scirocco came with and pictures?
many thanks in advance
A Few Questions I Need Help With?
77LAYFRAME
Re: A Few Questions I Need Help With?
Cost option, so none as standard. Likely to have been aftermarket or dealer-supplied (so various models) if fitted.77LAYFRAME wrote: 3. does any know or have pictures of the radio/cassette the early scirocco came with and pictures?
Although Ryan fitted one to his Storm - see the thread here (doesn't say what make it is, but Ryan could probably help) http://www.sciroccoregisterforum.co.uk/ ... rt=15#p491
Just had a look on the Drivers Found website, it has all the old brocheres. It looks like the GLS was the first Scirocco to have chrome trim on the rear lights.
http://www.google.co.uk/url?sa=t&rct=j& ... XBXM362c8A
A good read!
As Ed has said, radio was a dealer fit item, but the wiring was put in at the factory.
A good read!
77LAYFRAME
cheers for this reason being been looking for one for ages, and saw this one onthe edmundator wrote:Cost option, so none as standard. Likely to have been aftermarket or dealer-supplied (so various models) if fitted.77LAYFRAME wrote: 3. does any know or have pictures of the radio/cassette the early scirocco came with and pictures?
http://www.ebay.co.uk/itm/ORIGINAL-VINT ... true&rt=nc
so hopefully it should fit in well once i mod it to connect to my iPod/iphone
cheers again
77LAYFRAME
thought this was the case so someone must have broken the light and replaced it better get searchingianaudia4 wrote:Just had a look on the Drivers Found website, it has all the old brocheres. It looks like the GLS was the first Scirocco to have chrome trim on the rear lights.
A good read!
cheers again
may have a few more questions this week for you all as sorting parts out ready for rebuild
- Ryan
Twas a Blaupunkt Nurnbergthe edmundator wrote:Cost option, so none as standard. Likely to have been aftermarket or dealer-supplied (so various models) if fitted.77LAYFRAME wrote: 3. does any know or have pictures of the radio/cassette the early scirocco came with and pictures?
- dingorocco
Early and late inner "wings" are different around the front edge where the indicator unit sits. From the metal sections I have here you will likely be able to use the latter inner wing with the early wing and indicator unit however if your wishing to use the early inner wing and later wrap around wing and indicators you will definately need to adjust the sheetmetal to allow the late indicator to fit.
Can get pics of both if you need them, please message if so.
Grant
Grant
