brake upgrades for mk2
razor344
Post by razor344 »
i was going to do the mk2 master cylinder and servo upgrtade combined with some 256mm vauxhall vented disc convertion to my 86 mk1 golf cabrio
however im also going to do an engine change so the cars going to be off the road for a bit so ive bought a 92 rocco scala
but the brakes are shit on the rocco
can i fit the mk2 master and servo with the vauxhall 256mm brakes to the rocco the same as the mk1 golf ???
thanks marc
Re: brake upgrades for mk2
The braking system on any mk1 or mk2 scirocco is the same as the mk1 Golf, so the same mods will work.
However, if your brakes seem significantly worse than your cabrio, it's always worth making sure the fluid has been changed in the past 2 years and all the flexi hoses, unions rear wheel cylinders and friction materials are in good condition.
