Spot the Brake Servo
pajsh
Post by pajsh »
Can someone identify this servo.
Supposed to be off a Mk3 GTi but the end is not what I was expecting.
I was going to swap my 8" for this but it's not likely to work out.
The Serial Nr does not come up on Vagcat search or against a 93 Golf.
bengould
Re: Spot the Brake Servo
Post by bengould »
pajsh
Post by pajsh »
Thanks Ben,
Sometimes you can't see the wood for the trees :read:
