Brake Bias Adjuster
pajsh
Brake Bias Adjuster
Post by pajsh »
Anyone used one of these.
Tilton Screw Type Brake Proportioning Valve - Bias Adjuster Race Car / Rally Car
http://www.ebay.co.uk/itm/130742331954? ... 035wt_1159
Thinking of putting one in the front to rear brake lines and wondering do you have to have one for each circuit??
Or is there a better option??
ChrisPears
Re: Brake Bias Adjuster
Post by ChrisPears »
Generally cars with bias valves like that don't have split front/back circuits. the back brakes are fed (often by a balance bar pedal box) by a single pipe that goes to a t-piece at the back axle. Hence only one outlet. This set up is normally found on track/race cars, they tend to be maintaned more thoroughly, and driven differently so the safety aspect of the split circuit isn't vital.
If you wanted to keep a split circuit, you'd need two of those....but that doesn't seem like a good idea to me. How would you make sure the braking force is even?
Chaps
Post by Chaps »
To use one of these you need to join the 2 rear inputs together, feed it though the bias valve and then split it again.
Why do you need one of these bud? are your back brakes locking up before the fronts or something???
