I've been out the scene for years now but i still have the Scirocco, and i've just resurrected it from the garage. She fired first time
Anyway years ago - 12 ish i did the rear disc conversion and used the 16v handbrake cables but they have come to the end of their life so i need a new set
Can anyone point me in the direction of a supplier of these, or does anyone have a spare set
Also - My Eagle F1s have perished after many years of static storage. Now i got them through an MOT but i'm somewhat loath to drive any distance or any speed on them.
As the car is likely to cover less than 1000 miles a year now going forward and only on sunny Sundays, can anyone recommend a high performance sticky tyre. Not overly fussed on wet weather performance as i'll drive it like my missus when its wet or not at all. 185/60/14
Lastly - at the fine old age of 21 she has developed a touch of tin worm (the car, not the missus) and the Tornado Red is moving toward matt now so it's time for a refurb. Any recommendations on a quality bodyshop so that i can give her another 20 years life?
I'm in Tunbridge Wells, Kent
Andy
16v Handbrake Cables & Super Sticky Rubber & Bodyshops/resto
- Brunty
Re: 16v Handbrake Cables & Super Sticky Rubber & Bodyshops/r
Look at Camskill for tyres. If you want stickies then Toyo R888 or Yokohama Advan A048R are about as good as each other. I favour the Toyos as I've used them for years and have always got on with them. You'll need to run them at lower than recommended pressures. Measure the pressure after a run and reduce it then rather than guess at cold pressure. They like to run at about 26psi hot iirc.scalainj wrote:
You could still get handbrake cables from VW or GSF/ECP last time I needed some.
Brunty
- scalainj
Thanks for the tyre tips
I didn't realise the 16v cables were stocked by VW etc. Anyone know a part number?
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
- scalainj
Hello
I've tried GSF, EXCP & VW and none of them ahve any 16v handbrake cables. The part was apparantly discountinued in 2009
Any other pointers? Or are there particular branches or delears i need to speak to?
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
http://cgi.ebay.com/ebaymotors/VW-Sciro ... 3367102755
More Scirocco 16v's in the US than anywhere else, so a good place to look!
- scalainj
91 Scala
05 Alfa 156 Ti
06 Alfa GT
05 Alfa 156 Ti
06 Alfa GT
My local VW dealer ordered 16V handbrake cables from vw-classicparts.de
