translated using google.. sorry for the errors but i bet most people can work it out anyway
http://www.saugergroup.com/jens-scirocc ... querstrom/
Scirocco1 VW Type 53 bj 1979
Body:
Conversion to optics in 1977 by bj
flared wheel arches
painted in Porsche graumet
Interior:
Amaturen original
VDO Zusatzinstomente 12v, oil press and oil temperature
circuit chrome
Recaro seats obtained in the original material from the Golf 6 GTI
Brake:
Balance beam brakes
with front brake calipers Porsche 964, and bolted Alutöpfe 315mm discs in
the rear Audi S3 in ventilated 256mm
Rims:
E26 BBS racing wheels in 7 × 17
with Nankang 185/35 17
Engine:
! 2.0 8v motor racing mountain
block: Golf 3 GTI, 92.8 stroke crankshaft, precision-balanced and netriert
Pleul: Arrows
Pistons: racing pistons in 83mm
Oil Pump enhanced
MBE with Lambda Control
Cylinder head:
Cross-flow head from the Audi A4
group H Schrick valves, springs, and conversion to mechanical tappet
camshaft asymmetric about 300 degrees
HTN valve cover
Spiess .45 VGS individual throttle butterflies, Drilled to 48-Funnel, airbox
Exhaust:
4 in 1 Eigenbaukrümmer with 48 tubes
with 63mm then Bastuck engine muffler
Transmission:
Oettinger 16v lock
Alukühler special order
Performance:
213 HP
219 NM
at full power 7100u/min to 8100 U / min
unfortunately i can't link the pics due to them being on some sort of internet wizardry...
Lew
