Hi,
Can anyone suggest any plastic inner wheel arches that will fit the mk1 scirocco easily ? front and rear if possible
wheel arch liners
Re: wheel arch liners
Front - you can modify mk1 Golf liners relatively easily. I don't think there's anything else suitable. Not sure about the rear arches.
Keith and Phil in Suffolk have fitted Mk 2 Golf front liners with very little adjustment needed.
When I fitted my Front liners I used a Mk1 Jetta on one side and a Mk1 Golf cabriolet on the other, the Mk1 jetta liner is a better fit but alot harder to find, there is loads of Mk1 Golf Cabriolet liners about. You do have to trim a bit off the bottom corners to get it to fit.
Don't know about the rear.
On my Golf cabriolet there is a rear liner fitted on one side only, by the filler neck but it just covers some of the fuel pipe work, it does not stop the mud getting stuck up by the filler neck.
