Page 1 of 2
Clutch Cable lengths
Posted: Sat Apr 21, 2012 3:11 pm
by dozzum
Went and bought a new clutch cable for my rocco and fitted it today, but its too short!!! The place I bought it from had nothing listed for sciroccos so I bought one for a MK1 Golf KJet as I thought they should be the same. After fitting it I have no free play and no adjustment left to compensate for it.
After a bit of searching around I found a mention from someone on the mk1gti forum that the golfs take a 1470mm cable (what I bought) and the sciroccos take a 1490mm cable. Is that 20mm enough to stop my clutch slipping (practically new clutch).
However I have also seen sites selling cable that are 1660 mm long.
My cars an 83 Kjet 1800 cc.
Re: Clutch Cable lengths
Posted: Sat Apr 21, 2012 4:59 pm
by Old Mac Rocco
Cpt Custom has one for sale just now.
Might be worth a pm to check length ???????
Posted: Sat Apr 21, 2012 6:39 pm
by ianaudia4
Sciroccos with DX engine use 1490mm long clutch cable. I have replaced both of mine and they were 1490mm.
Posted: Sun Apr 22, 2012 10:27 am
by dozzum
Can anyone explain why some engines need a 1660 cable? Gsf say it is listed as bein for gtx's from 84 onwards. But I cannot understand why they will require a cable that is so much longer. Have to wonder if it would make routing a bit smoother and make the pedal lighter.
On a similar note does anyone know how to stop the clutch pedal travelling so for to the floor. Since I removed the carpets it catches on part of the steering column when fully pressed. There is no physical stop for it inside the car that I can see.
Posted: Sun Apr 22, 2012 10:49 am
by ianaudia4
You could do a bit of research yourself ref lengths of clutch cables. I know that DX engined cars require a 1490mm cable because when I got my Storm I ordered one from GSF, and they sold me a 1470mm, I went to the dealer and they checked the part number size etc, even though it is obsolete from them! I ended up getting one from ECP!
The part number for the 1490mm clutch cable is 532721335J.
Posted: Sun Apr 22, 2012 11:33 am
by dozzum
Ye I have all the part numbers etc from vagcat cheers. I was just trying to understand why they sell such a long cable for later models when I can see no reason for it?
Posted: Mon Apr 23, 2012 3:57 pm
by dozzum
Nowhere seems to sell the 1490 cable anymore, anyone ever fitted the 1660 cable to a dx engine before? As long as the difference between the inner and the outer is right it should be ok as far as I can tell.
Posted: Mon Apr 23, 2012 8:59 pm
by Old Mac Rocco
As above ^^^^^^^^^ drop Cpt Custom a pm to check what engine Poppy was and what length his clutch cable is.
His is only 8 squiddey diddley plus p&p.
Posted: Thu Aug 22, 2013 6:56 pm
by Jimmytdi
Ive just had exactly the same problem, bought a GSF cable (1448mm) and it was too short! I only just managed to get it fitted at all but only with the adjuster wound right in and then the clutch wouldnt fully engage.
Measured the old vs new one and mine is about 50mm longer (probably the 1490 one)
Are these still available? GSF and Euros only stock the short one. Or would a 166mm one be ok?
Posted: Thu Aug 22, 2013 7:18 pm
by ianaudia4
Your car needs a 1490mm minimum, try Heritage VW?
Posted: Thu Aug 22, 2013 9:07 pm
by dozzum
Ye I had to go through vw heritage and get it sent from germany.
Don't think they had many left either. I was tempted to buy two but they weren't cheap.
By the time this one goes the dx will probably have died and been replaced with something else.
Posted: Thu Aug 22, 2013 9:31 pm
by ianaudia4
A quick search on Ebay brought up this:
http://www.ebay.co.uk/itm/CLUTCH-CABLE- ... 19e07d7120
Shows length as 1487mm, near as damn it!
Posted: Fri Aug 23, 2013 6:26 am
by Jimmytdi
Cheers dude! Looked at quite a few on ebay but all i found were the 1448 or 1660mm ones, mustve gone straight past that one
Just ordered one
Posted: Fri Aug 23, 2013 5:28 pm
by dozzum
Let me know how it fits.
Posted: Fri Aug 30, 2013 8:45 pm
by GTXTRA
Recently acquired a clutch cable from Eurocar parts specific to Sciroccos.
646 44 0350 is the part number.
