1.6 heads
rob_pandy
1.6 heads
Post by rob_pandy »
the head on ajays mk1 rocco 1.6 has a problem, its a early one with the water outlet to the rad on left hand side between number 1 and 2 plugs. he been given a later 1.6 head from a mk2 golf but the water outlet is between number 3 and 4 plugs, can he use this headn or is it completely wrong. thanks in advance rob
big nick
Re: 1.6 heads
Post by big nick »
the head will bolt up to the block and work just fine.. only thing you need to worry about is the top coolant hose - if it was me i'd get the hose to match the head but if you have scissors and some metal/pvc pipe you can get creative and chop & route the hose any which way you like : )
do I really want a carb'd valver? answers on a postcard...
Re: 1.6 heads
I thought 1.6 heads have the water outlet between 1-2 and 1.8 heads 3-4 ?
So could it be a 1.8 head?
