In 5th gear the MPG indicator works fine, just like it always has. However, the problem I have is that the LED gearchange indicator has stopped illuminating when I need to change gear :( So I'm wondering if any of you guys who have the same clocks as I have could tell me if it's more likely to be the LED, the fuse, or something else?
I'd like to have it working properly again but I'm not too hot with electricity
cheers fellas
