rocker cover gasket
rocco robin
rocker cover gasket
Post by rocco robin »
do the scalas run a cork gasket or a rubber one?
carnt find anything in the tech department
Re: rocker cover gasket
cork as standard. rubber one is a popular upgrade
jim91
Post by jim91 »
Was a cork one on mine from memory dude, very cheap from GSF
rocco robin
sweet cheers boys
If you go to a dealer and ask for a rocker gasket they will (should!) sell you a MK3 Golf one which is rubber and one piece. In the box is included studs to swap your existing ones for. I have changed both mine for these, no leaks and easy as to fit.
Dougiegreenskala
Post by Dougiegreenskala »
:hi: Same as Ian, rubber no probs. :hugegrin:
Bill
Post by Bill »
Sorry to sound daft but, why do you need new studs, plus any part number please :hi:
wasted
Post by wasted »
The rubber gasket is thicker than the cork one, hence the need for new studs.
PeteGLi
Post by PeteGLi »
Bill wrote:Sorry to sound daft but, why do you need new studs, plus any part number please :hi:
wasted wrote:The rubber gasket is thicker than the cork one, hence the need for new studs.
The studs for the cork gasket have a shoulder on them.
The studs for the rubber gasket do not.
If you search for 'rocker gasket part number' you should find a post with the part number and maybe even a picture. :whistle:
alscoob
Post by alscoob »
Jut ordered one myself from local VW dealer £9 all in 8-)
PeteGLi
Post by PeteGLi »
alscoob wrote:Jut ordered one myself from local VW dealer £9 all in 8-)
Sounds cheap for the gasket and the studs. Are you sure that includes the studs?
^^^^^^^^^^^What Pete said, I paid about £17, if it does you have grabbed a bargain, good skills!
alscoob
Post by alscoob »
ianaudia4 wrote:^^^^^^^^^^^What Pete said, I paid about £17, if it does you have grabbed a bargain, good skills!
Hope so......will find out later as it's due in today for collection, I'll confirm later...
....Well should have known better. Turned up to collect it today & guess what... yes it was a cork one, despite the parts person saying when ordered that they did not do them anymore & I was getting the rubber one with studs!! :ire: So I politely said you can put that back in stock & had my refund.
Drove 200yards to GSF & bought a rubber one for £10.20...as I have the later DX engine they say that it 'should' be ok with original studs... I'll see later :swoon:
MacColl
Post by MacColl »
It's precisely this scenario that I have ended up rarely using VW or for that matter GSF. Trying to explain to someone that a lot of 8v parts off something like a MK3 Golf will fit a Mk2 Scirocco is impossible :dash:
If you are stuck and it has the correct studs..
http://www.veedubmachine.co.uk/index.ph ... ucts_id=94
oh and another option is to grind the shoulders off the existing studs to work with a rubber gasket, tedious I know :roll:
Bonusrocco
Post by Bonusrocco »
When i did this the new studs seemed massive. old ones would have done...
So many plans, so little time
