Part Number
Part Number
Hello can anybody help me on here i need to know the part number for windscreen wiper stick on a mk 2 scala Scirocco dx model 89.many thanx to all that helps its more then appreciated.
Re: Part Number
Do you mean the wiper stalk on the steering column, or the wiper arm on the outside of the car?
Re: Part Number
I mean wiper stalk on the steering column.PeteGLi wrote:Do you mean the wiper stalk on the steering column, or the wiper arm on the outside of the car?
Re: Part Number
Nate wrote:http://www.vagcat.com ;)
ok this is the part numbers i have from the web site link you give me on here---
(6) (why hidden?)
switch for windshield wipper, wipers and washer and multi function indicatoroperating / F >> 53-E-042 000
(why hidden?)
satin black
(6) (why hidden?)
switch for windshield wiper, wipers and washer and multi function indicatoroperation with memory button / F 53-F-000 001>>
which is the right one or does it not matter ? many thanx.
Re: Part Number
You need to sign in to the site to see the part numbers hence all the why hidden stuff. The numbers you need are these:
171953519B
171953519B 01C
satin black
(6) 331953519B
The difference is that the bottom one is for the MFA, fairly pointless if you car isn't fitted with it
171953519B
171953519B 01C
satin black
(6) 331953519B
Re: Part Number
ok great, many thanks Mr Funk.Mr Funk wrote:You need to sign in to the site to see the part numbers hence all the why hidden stuff. The numbers you need are these:
171953519B
171953519B 01C
satin black
(6) 331953519B
Re: Part Number
Ok the part Iam after new the interior wiper arm stick seems to be obsolete i have spoken to gsf, euro car parts and vw classic Heritage can anybody help or know were i can this part new please ? many thanx.
Old Mac Rocco
Re: Part Number
Don't know about new but I know where there is one if this is what you are after.
I may be going here on Sunday so could have a look to see if it is still there.
Pm me with your max limit if you are interested, it's just that I don't want to buy it and find out later I spent too much on it and get left with it.
Not even sure how it all comes apart.
Re: Part Number
I bought a new one, but that was a few years ago. Think I got mine from the Stealership.
Mac - its just a couple of screws on the front. Unhook all the wiring and it comes apart fairly easily.
Re: Part Number
Geebeats is after one for an injection car, it has the MFA button on.
Re: Part Number
Yes that is right Ian ,many thanx.ianaudia4 wrote:Geebeats is after one for an injection car, it has the MFA button on.
Re: Part Number
Bear in mind that the mk1 + early mk2 Golf + mk1 Cabriolet stalk is exactly the same.
Also, the stalks from an 86-89 mk2 Golf will fit BUT you will need both stalks and will have to modify the plastic cowling slightly as these stalks sit straight rather than at an angle.
Re: Part Number
ok how early are we talking in years 80,82,83,84 ? many thanx.
mr.brown wrote:Bear in mind that the mk1 + early mk2 Golf + mk1 Cabriolet stalk is exactly the same.
Re: Part Number
Ok thanx for all your help with all of this but the part is now absolute i have been in touch with gsf , euro car parts, vw classic heritage etc it did came on 3 different golf models 86, 87 and 88 models and all so the mk 2 scirocco, but iam now looking for a very good 2nd hand one get at me on here hopefully, please if you know any one who has one, it would be more then appreciated many thanx.
