Where to find a quickshift for a MK2 Scirocco
Where will I find one that will fit?
On Ebay they are down as MK2 Golf and MK2 Scirocco being the same, I know from using a MK2 gearbox before that they are different.
I tried the MK2 Golf GTi weighted shift and it looked too short.
Has any on bought one from Ebay, and did it work ??
Re: were 2 find quickshift for mk2 scirocco
You want one advertised as a Mk1 golf shortshift.
These are the shapes you are looking for:
http://www.ebay.co.uk/itm/Neuspeed-Shor ... 335924d357
or
http://techtonicstuning.com/main/index. ... e79c7eodn5
alternatively, have a look at the Missinglinkz website - http://www.4crawler.com/Diesel/ForSale/ ... kage.shtml
or
Look at the Short Throw Shifter section on this page. You can make one yourself in a few mins without complicated tools.
http://www.4crawler.com/Diesel/ForSale/ ... ShortThrow
Also have a look on here on this link kindly supplied by MacColl.
http://vagdrivers.net/forums/index.php?showtopic=39188
This is an alternative method.
The position of the sliding part determines the % of the adjustment.
Good luck.
Good luck.
hii know have a weighted link. its shorter than the originall, dose this mean it wont fit??
Yes, you most likely have a mk3 Golf item which will fit a mk2 but not mk1/Scirocco.gplategt wrote:hii know have a weighted link. its shorter than the originall, dose this mean it wont fit??
Same as the one I got for mine,you need to keep an eye on the allen head bolt on the bottom of the relay shaft,as it can work itself loose over time,the standard one has a nut on the end
Sorry, I meant it will fit a mk2 Golf - I should have been a bit clearer.gplategt wrote:mr brown it dosent fit itz like half the size?
Re: Where to find a quickshift for a MK2 Scirocco
hay its the bottom part of my linkage i need its live a v or a y bracket,it has alot of play, dose any one on heer have parts of the linkages forsale and i hope to get some gears soon
Anyone know where to find a decent short shift and how to install one
