are veedubmachine.co.uk parts any good
traindriver69
Post by traindriver69 »
hi all i am looking to buy some front wishbones for my mk2 scirocco from these guys they say the wishbones are quality parts but has anyone had any dealings with them and are the parts good .
many thanks in advance
seanr68
Re: are veedubmachine.co.uk parts any good
Post by seanr68 »
£42 isn't a bad price delivered....i'd be tempted to get some cheapys of the bay, get em blasted, welded, plastic coated and fitted with poly bushes. May cost a bit more but, the handling will be better, they'll last longer if coated properly and, you'll have made em yourself so kudos points as well.
Who do you drive trains for?? I drive for Freightliner. Just off ter kip, up at 01:45. :crying:
traindriver69
East Midlands Trains
£42, is that each? VW Heritage/Big Boys Toys sell them for £45 including bushes and ball joint.
go-for-it1
Post by go-for-it1 »
Hi traindriver,
Use this link: http://www.vwspares.co.uk/scirocco_suspension.php. They do the Febi wishbones Part No 08397 complete with bushes at £18.90 each including Vat. I fitted 2 of these wishbones and 2 ball joints and they are good quality and fit, in fact all the stuff I have bought from them have been good quality. Febi is OEM standard kit on most VW's. Left and right hand side wishbones are the same. Would recommend giving them a couple of coats of smooth black hammerite on top of the supplied coating before fitting to give extra rust protection. I have used VWS a few times and they are good with emails to let you know the order status but I normally wait till I need a few things so one delivery charge can cover everything.
Rob
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
MacColl
Post by MacColl »
I bought these wishbones think I got them cheaper than they are quoted on the website now. For 29.74 plus postage you are getting them with the bushes fitted which I still think is pretty good for the price. They are made by the JP Group Germany and seem to be good enough quality. The bushes seemed fine. I bought them for the convenience of being able to just bolt them in. I bought a bunch of stuff from them which lowered the overall postage.
I bought the rest of the bushes febi ones for the front end from the place mentioned above. I couldn't fault them, just did everything online because you can get the exact price as you prep an order.
The only Poly bushes I will be fitting are on the main rear axle Rally design ones and rubber VW heritage ones for the arbs. For daily use after all.
The guy is very friendly and helpful at Veedubmachine, just make sure he has stuff in stock as he had made an honest error with one of my orders when he thought he had something in stock but immediately reimbursed me.
MacColl
Post by MacColl »
Heres a pic of one of the veedubmachine wishbones.. (you don't get the ball joint)
Bonusrocco
Post by Bonusrocco »
I bought some door locks and flag type wing mirrors from veedubmachine - very poor quality i'm afraid. :( Door locks didnt fit or work, and the wing mirrors drooped as the ball joint was not designed well. Thats just my experience, I too go to AVS now.
So many plans, so little time
traindriver69
I have brought the ball joints already but the old ones are riveted in so thought just to buy new wishbones to save time trying to drill them out.
seanr68
Post by seanr68 »
ianaudia4 wrote:£42, is that each? VW Heritage/Big Boys Toys sell them for £45 including bushes and ball joint.
I should've highlighted the fact that £42 was for a pair....sorry peeps. :blush:
traindriver69
wishbones have just come on the advice of a member on here i got them from vwspares.co.uk only problem is that i ordered the set complete with bushes so i expected them to come ready fitted they are not so how hard are they to fit to the wishbones also i have noticed that there is some rust on the welds is this normal.
stu.gtx
Post by stu.gtx »
I wouldn't expect them to be rusty when you buy them but they will rust pretty much straight away on the car anyway. Best to give them a coat of hammerite or something.
