Found this while surfing around: http://unwiredtools.com/utcis-v.asp
Anyone used, or got opinions on this product? Looks like it could be a good idea and its reasonably priced too.
Interesting, mappable, K-Jet system
Re: Interesting, mappable, K-Jet system
Nice idea, apparently very unreliable. and not 'closed loop'
Forgive my "numptiness"m whats closed loop?chopperoli wrote:Nice idea, apparently very unreliable. and not 'closed loop'
Closed loop is usually an oxygen sensor in the exhaust system that "sniffs" the burnt gases and tells the ecu controlling the fueling how much fuel should go to the cylinders depending on how much oxygen is detected.
Too much oxygen measured means not enough fuel for a set amount of air and a lean mixture and too little means too much fuel and a rich mixture.
HTH :)
HTH :)
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
