Clutch cable
Clutch cable
Could anyone confirm the part number on the bandit's clutch cable please as I want another one.
1.8 kjet
Assuming its:
532721335J
PeteGLi
Re: Clutch cable
Post by PeteGLi »
That part number is for chassis up to VIN code 53 F 060 000.
You might want part number 534721335 which is for chassis after VIN code 53 G 000 001
Measure the length of your existing cable, as the one on my GTX is approximately 1640mm long. I got it from GSF so don't know what its corresponding VW part number was.
Re: Clutch cable
Having changed a few clutch cables I know they are 1490mm for the DX engined cars. These are discontinued at the dealers now, I bought mine from ECP.
Before fitting pour some oil down the cable, stops it rusting from the inside, you can't beat a bit of lubrication!!! :hugegrin:
Re: Clutch cable
Cheers guys. Saw the different lengths and wondered.
Re: Clutch cable
Odd. Called ECP and they've stated it's thelonger of the two. Picking one up tomorrow, if it's wrong I shall return to the venue Vern in hand.
