HELP HELP HELP
rocco balboa
HELP HELP HELP
Post by rocco balboa »
i need a new warm up reg for my scala inj , currently finding them around £250 which will put her on the scrap heap any suggestions welcome
Re: HELP HELP HELP
The Wur on the front?
I think I have a spare.
rocco balboa
Re: HELP HELP HELP
soz for delay mr funk , dont know what to do ,my mechanic is saying he wants me to source him a new one oblivious to the cost , is there a way of knowing if it is faulty ...? tried to get her running properly myself and there seems to b so many things it could b. Ive fitted new injectors , blown fuel lines back wiv air, checked filler neck and tank best i can without droppin tank out ( looks like grief ) new plugs , oil , filters. It jus takes ages to start , doesnt like any pedal until proper warm then when u drive its spluttery unless u give it the full beans. Jus seems like bits in the fuel still ............ after i cleaned out metering head which had a load of crud in it an blew the lines threw it was a bit better , i dont know if im convincing myself this is still an easy fix even after all ive done already. Any suggestions would b much appriciated. Ben
PeteGLi
Re: HELP HELP HELP
Post by PeteGLi »
You can check its electrical resistance, and that it is getting voltage - Haynes gives the value and procedure.
Also, if you have not done it, you should check the fuel system for correct pressures and flow.
Re: HELP HELP HELP
I don't run a Wur on mine at the moment. Got to be honest it starts first time every time regardless of the weather. Takes a few minutes to get running properly mind.
Think your best betbisnto take Petes advise. He's an utter Jedi when it comes to this sort of thing and you don't want to be paying out for stuff if you don't need it
ghost123uk
Re: HELP HELP HELP
Post by ghost123uk »
Not duff petrol is it, it happens !
rocco balboa
Re: HELP HELP HELP
PeteGLi wrote:You can check its electrical resistance, and that it is getting voltage - Haynes gives the value and procedure.
had the voltage checked today an there is an issue with it dropping off after starting. cheers pete fingers crossed.
rocco balboa
Re: HELP HELP HELP
Mr Funk wrote:I don't run a Wur on mine at the moment. Got to be honest it starts first time every time regardless of the weather. Takes a few minutes to get running properly mind.
found a company that will recondition my WUR checking hot and cold pressures for 90 gold coins which is a much cheaper option than b4 but im intrigued as to what u an a few other people have mentioned , an thats not running 1, is this a simple bypass that i could do? ........please enlighten me
