Are driveshafts interchangeable with CV joints?
hyperdrinky
Post by hyperdrinky »
OK guys, bit of a hair-pulling evening. In the midst of fitting a replacement gearbox on Rocco and have run into a snag. The muppet that owned the car before me has changed one of the 100mm output flanges on the gearbox with a 90mm one. Now, I have 6 flanges altogether, so I can change these to whatever I want, but it means I have one driveshaft much heavier than the other. Now, I had assumed that the offside (drivers) was heavier because it was longer, but I don't know.
My question is, can 90mm inner CV joints be fitted to a 100mm driveshaft or vice versa? I suspect I'm just going to put it back to 1 of each, but I'm a purist and if I can replace it cheaply with 2 of the same size I will.
Thanks for the info guys.
fonzooorooo
Re: Are driveshafts interchangeable with CV joints?
Post by fonzooorooo »
Pretty sure we found they would fit. Just the external diameter that's different.
Bonusrocco
Post by Bonusrocco »
I remember reading that they are interchangeable, just a matter of removing a circlip and tack welding or machining the shaft a little. Check out the 16v conversion download on mk1golf.org forum, in the guide pdf its listed all the driveshaft options you can use together.
So many plans, so little time
Post by mr.brown »
From what I remember it's the outer CV joints that are interchangeable - not the inner ones - at least not from 90mm>100mm. I'm not sure about the other way around as I don't believe anyone has ever tried such a thing :hugegrin:
bengould
Post by bengould »
Yes they are interchangeable.
I got a gearbox with driveshafts from a mk2 golf to go in my car and have had to swap the CV Joints off the golf shafts onto the scirocco shafts.
It was a bit tricky but they do swap over.
Ben
