VW Hose clips !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ghost123uk
Post by ghost123uk »
Must have been covered before but after lots of Googling around I got no real answer (well none I had not already figured out for my self)
Those spring loaded coolant hose clips :twisted: :twisted:
We currently have 3 VW's (2 x Rocco's and 1 x T25 flat 4 Camper) and of course they all have at least 10 of those horrid clamps.
Each time I take one off I try to replace it with a "proper" jubilee clip but sometimes I either don't have a suitable jubilee clip to hand, or the clamp is simply a mare to get off in the first place due to space restrictions etc.
I know there is a snap on tool but they are VERY expensive :shock:
I also know (and have done it) that you can carefully Dremel cut them off (bit risky to the hose !)
What do you do with them ?
Re: VW Hose clips !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Cut them off with a dremel then get a set of good quality Stainless jobbies.
seanr68
Post by seanr68 »
I use a pair of "long nosed mole grips". They get into tighter spaces as they're not half as bulky as standard grip and the longer nose gets you right on the clamp. Now what i've also done is grind out a a notch on each face at the end of the grip. This mean you get better purchase on the clamp. If you need a pic of them, let me know. :good:
I also use mole grips.
Risocco
Post by Risocco »
Mole grips is where its at mate :good:
ghost123uk
Yeh, I should've said I have used mole grips, I have the holes in my hands to prove it :?
Oh, and ping and your eye is out :shock: (at least you don't need safety goggles with screw clips !)
I'm going to buy a whole selection of stainless jubilee clips to have at the ready each time I have to take one of them bliddy clips off !
roccodave
Post by roccodave »
i have allways used molegrips and just moved them back and left them on the pipe that way if they do ping off you wont lose a eye and its ready for you at the right angle when you need to put it back on :yup:
i cut the tang off the inside that limits the amount you can open them. this gives you a bit more too play with.
jxp
Post by jxp »
I use a pair of these, not an exact fit but do help as lock in place. I also used to use mole grips
http://www.ebay.co.uk/itm/QUALITY-HOSE- ... 4996wt_832
2002 Passat 1.9 TDI 130BHP
DannyH
Post by DannyH »
mole grips or pump pliers :yup:
Danny
http://www.ebay.co.uk/itm/360362839102
depending on which one you're working on, these are good. i got mine for £15 from the local toolvan, so you should be able to find them cheaper than that ebay link.
hyperdrinky
Post by hyperdrinky »
Nate wrote:http://www.ebay.co.uk/itm/360362839102
I'll second that one. I use these all the time and they're fantastic. The only hindrance is that sometimes they don't open as wide as they could which makes it difficult to get them over the ridges.
