mk2 heater blower speed
iroberts696
Post by iroberts696 »
Am down to only '3' as blower speed have replaced switch ( fan can be noisy ) anything else to try before changing fan ?
You don't understand Newton's Third Law of Motion?
It's not rocket science, you know
Re: mk2 heater blower speed
Post by mr.brown »
Sounds like the fan speed resistor is knackered. Remove your scuttle cover and you should be able to see it.
(Can't remember how you change/fix it though - been so long since I did it. :blush:)
Picture of one on ebay (it's the black tube thingy)
http://www.ebay.co.uk/itm/VW-GOLF-MK1-S ... 0884628096
iroberts696
Thanks, had a spare from last car, however destroyed it foolishly trying to remove the loom ! see seller has 1 more on ebay but expect an unused one would have longer life main dealer in Rutherglen tells me they dont exist as do vwheritage - anyone know better - as it looks fiddly to fit including loom and probably not good idea to cut and clip ?
Post by mr.brown »
Try a Wanted ad here first ;)
iroberts696
Last time I did that someone pointed me at wvheritage with a part nr , theres a s/h one on ebay at the mo but seller was more expensive for s/h switch than vwheritage were for new !
