Ignition Switch
DannyH
Ignition Switch
Post by DannyH »
hi guys does anyone know any easy way to remove the wee screw that holds the ignition switch in place? :dunno:
last time i did it i had to remove the steering column and i really don't want to have to do that again! :yup:
ta in advance
Danny
PeteGLi
Re: Ignition Switch
Post by PeteGLi »
You have to remove the ignition switch housing from the column in order to get to the screw. It can only be accessed from the inside ofthe housing.
Re: Ignition Switch
it's deliberately not that easy to remove - once it's of you can start the car without the key ;)
