Recently after a heafty journey my mk2 gt2 decided that the vacuum central locking didn't want to work anymore, so i was just wonering what would be the logical place to start on this one as i have little experience of this sort of central locking unit.
cheers in advance
Tom
Central locking???
- Jay4424
Re: Central locking???
Has the pump stopped pumping? Has all of the locks stopped working automatically? ...can you hear suction anywhere?
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
I have a pump.
tmcmahon92
it would appear so. locks only work individualy now. How much for the pump mate?
tmcmahon92
yeah i have to no avail, it did however take me at least 2 hours even to think to check that :SNate wrote:you have presumably check the fuse?
check for power to the pump before replacing it. if you don't have access to a multimeter, just use a lightbulb with one side connected to earth. when you find power, it will light up. once you've found the one that makes it light up, keep that connected and try using the other side of the bulb to find the earth. earth wires are normally brown or brown/white. if there isn't any power there while trying to lock/unlock then it isn't going to be the pump!
