DOWNPIPE GASKET
johnsm
DOWNPIPE GASKET
Post by johnsm »
MY 84 STORM HAS A LEAK AT THE EXHAUST DOWNPIPE GASKET WHERE IT CONNECTS TO THE MANIFOLD WITH THE TWO SPRING CLIPS ,CAN ANYONE TELL ME THE PART NUMBER FOR THIS GASKET AND THE DIMENSIONS FOR IT AS THERE ARE SOME FOR SALE ON EBAY,THE ONE ON EBAY LISTS IT FOR SCIROCCO,CAMPER AND OTHER MODELS AND HAS A BORE OF 72mm AND IS IT EASY TO FIT,I HAVE READ THAT THE CLIPS ARE MURDER TO TAKE OF AND PUT BACK ON. ANY HELP WILL BE APPRECIATED .REGARDS JOHN
Re: DOWNPIPE GASKET
You can get the downpipe gaskets for a few quid from Euro Car Parts, it is also worthwhile changing the clamps as well for the few quid they cost as well. A lot less hassle than EBay IMHO!
steve GT VW
Re: DOWNPIPE GASKET
Post by steve GT VW »
the part is called a manifold V Ring gasket, I had to source mine from ebay germany, as I could not find one here at the time
Re: DOWNPIPE GASKET
GSF also used to sell them. I found went I thought my Gasket had blown it was infact a hole between the two exhaust pipes not the gasket.
You can check where the hole/leak is by using a bit of garden hose holding it to your ear and moving the other end where the noise is coming from. Be carefully not to touch the hot exhauts with the hose or it might melt!
Might be worth a check?
As with all things the C clips are easy to take off/put back on if you have the right tool. I think there is something about this in the FAQ.
ghost123uk
Re: DOWNPIPE GASKET
Post by ghost123uk »
mark1gls wrote:I found went I thought my Gasket had blown it was in fact a hole between the two exhaust pipes not the gasket.
Same here :evil:
Re: DOWNPIPE GASKET
word of warning make sure you get the compressed wire wool type gasket. these deform to the shape of your manifold and do a much better job at sealing than the solid metal type which i tried and it didnt work!!! much to my annoyance as them c clips are a pain to get off!!!
