Need Fuel pump, accumulator and brackets
Raga-blipo
Post by Raga-blipo »
Hi! Im trying to locate a new inline fuel pump, mouting bracket and fuel accumulator on ebay, with little luck. Found a link in another post to the mounting bracket for a mk1 golf, and they have the fuel pump also. Does anybody know if they will fit my 1990 GTII (JH 1.8i engine)? Tried GSF but the only listed fuel pump is marked with "carb". Does anybody have any other sources? Havent found the accumulator anywhere. Also open for second hand items.
http://www.golfmk1.co.uk/Items.php?cat= ... =FUELPUMPS
mikeki
Re: Need Fuel pump, accumulator and brackets
Post by mikeki »
:hi: Hi
I bought an accumulator from GSF last week, a brand new bosch unit from their Sheffield branch, it is listed under the MK1 golf supplies and is identical to the unit for the scirocco. The support is more complex, you need to get one from an old golf, again identical to the scirocco mount. Hope this helps.
Mikeki :bye:
Mk1 Storm 1981...sold
Mk1 GT(GLS) French Version 1978...still under development
Mk1 GLS 1980...sold
MK1 Golf GLi Cabriolet
MkII GT 1991....nice and quiet
Mad as a badger...and getting worse!! Much worse! This is not looking good is it ! Is there a cure?
MrD
Post by MrD »
Sorry to Hijack your thread but,i am also after a shiny new accumulator,how many pennies did it cost ? after 1 purley for cosmetic reasons,mine is rusted to buggery,and as it will be on show under my bonnet i would like it to be nice and shiney :blush:
