clutch cable bulkhead problems
Re: clutch cable bulkhead problems
as you can see the linkage arm bolts to the clutch lever with a standard m8 bolt through a hole conveniently already in the clutch pedal.
i haven't bolted it in properly year but 2 m6 nuts are needed to fix the main body of the unit to to bulk head
apologies for the late pictures I've not been very well the last couple of weeks and have had to catchup on a backlog of work since last week.
as you can see its a really good bit of kit and would recommend it.
only downside is the need to enlarge the clutch cable hole but other than that its well worth it.
thanks again mark for the kit its really awesome!!
mark watson
Post by mark watson »
great james , what you can do inside the cab is cut a bit of 25 x 3 or 5 mm flat bar then bolt up across the 2 studs for additional support , looks way neater with the cable not draped over the motor , but a pleasure seeing the guys sticking them in , will sort a lot of hassles out , seen 2 many golfs with butchered firewalls
mr alpine92
Post by mr alpine92 »
james butler wrote:Image
looking good james i see you not put your split pin in yet, ;-)
lol not yet chris I've still gotta grind the hole for the clutch cable round so the grommet will fit properly.
time just seems to escape me nowadays lol
Red Rocco
Post by Red Rocco »
Hi, sorry to revive an old thread but are these still available? If so I'm definitely interested. Got through a couple of clutch cables and would like a more permanent solution that doesn't involve hacking the bulkhead about.
Post by mr.brown »
If Chris - mr alpine92 - doesn't have a spare one I can sell you mine as I'm unlikely to be fitting it.
mr alpine92
mr.brown wrote:If Chris - mr alpine92 - doesn't have a spare one I can sell you mine as I'm unlikely to be fitting it.
iv only got one lift mr brown, im using it on rocco when fitting new engine best email mark ;-) ,
@red rocco you will still need to drill holes in the bulkhead to fit this mod.
alternatively make yourself a large repair plate and bolt it into position.
do not weld it as the bulkhead flexes with the press of the pedal and will crack.
baldrob
Post by baldrob »
Hi just read your post, just wondering if you have any more of these kits please? Or if you have a contact for the company that produces them?
Yours desperately
Rob
the guy that got mine and chris aka mr alpine was mark watson as seen posting above.
hes the person you need to speak to.
Post by mr.brown »
In Parts for Sale.
Red Rocco
Post by Red Rocco »
Hi, sorry for the late reply, definitely interested, just fitted a bulkhead patch not too happy with it as getting the cable to line up without rubbing is a nightmare! Just wondering how much you want for it?
Rob
Red Rocco
Post by Red Rocco »
mr.brown wrote:In Parts for Sale.
Just seen it, now sold! I'll keep a look out for another.
Thanks,
Rob
