My £66 Charity Case GT - 128bhp Homebrew
Risocco
Re: My £66 Charity Case GT
Post by Risocco »
Unions arrived, now just waiting on the correct fluid reservoir for my master cylinder. Always something.....
Yesterday was pretty much rained off. Have however re-routed my lines for the master cylinder using this magnificent piece of kit...
So now looks like this...
Will refill the system and bleed tomorrow when I have an assistant available. Only thing is for the life of me I can't remember how the spring clips on the back of the servo? Will post an appropriate thread up.
Also, dug out the TSR big valve head I will be running...
Connected manifolds, havn't painted the inlet just yet incase there is a fuel leak...
And fully torqued up on the block with Newmans cam and new splash guard...
Really hope to be in the position to turn the key by friday. Looking possible so far!
The Autoad
Post by The Autoad »
Are you done yet?
does this help with the spring on the back of the servo?: http://sciroccoregisterforum.co.uk/faq/ ... e-upgrade/
dont know if the pics are close up enough for you pal?
The manifold paint may smoke a bit when you start up, but it will clear! Yummy TSR head indeed :pilot:
Risocco
Post by Risocco »
Patience Padawan, nearly done. :beers:
Pete sorted me with my spring issue. Will pay more attention next time rather than going gun-ho with a pry bar when removing stuff. :diablo:
Will have to run the 2 inch downpipe as my Jetex is the 2 inch system, single output back box.
Left to do....
-time engine
-bleed brakes
-connect various looms and cables.
Basically a steady afternoons work. Will have to run the standard rocker cover tho as my airbox will not clear the MK3 one. Boo!!!!
roccy gt2
Post by roccy gt2 »
wow just read all through this thread and seen the work on your car it is awsome stuff and u saying at the begining u've baught it to learn some mechanics u seem to do well and loving the work keep it up dude and i'm looking forward to reading ur post saying it lives and runs good luck to ya
..ian
mk scirocco gt2, on coilovers and fully pollybushed with 2.0 16v soon to come
Risocco
Post by Risocco »
Cheers dude! Too kind. Really can't wait to get the old nail back on the road.
Risocco
Post by Risocco »
1 step forward, 3 back....... :ire:
Got these tho, big improvement, just need to clean the locks up a touch...
And after bleeding the brakes, she is finally on 4 wheels again with added standard indies. Love the look...
I miss this car, sad as it sounds........
Risocco
Post by Risocco »
Bought some stuff......
Need the senders for the VDOs tho.
More detailed update soon. Have re-found the enthusiasm for the car again :beers:
Risocco
Post by Risocco »
Right, to summarise. Brakes are bled, but when I was timing up the engine, the camshaft bearing sheared a stud, so had to take the head off again and get that repaired. Then lost interest.
After xmas, I found the love again, apart from the above purchases, I made a huge order from Auto Silicone Hoses. The result...
Started making my hoses, using the old ones as templates. Heres the bottom rad hose for example...
In terms of the metal coolant pipe, I made my own from a MK2 Golf Gti, and standard Scirocco carb. Mainly to bypass the water to inlet output and the oil cooler output. Here is the gear...
This was fitted today along with a new thermostat housing and low temp thermostat.
Heres a random pic of some more hoses I made up, looks better than the pics show...
However, head will be coming off again (its not torqued on at present, just resting to ensure hoses meet flange on front of head) due to this recent purchase...
Twin Dell 40s baby! I never liked having money anyway......
Risocco
Post by Risocco »
:mafia:
Risocco
Post by Risocco »
Productive day.
First, after a touch of filing for clearance, got both manifolds on the head and after, the head torqued on. Hopefully for the last time :hehe:
Exhaust manifold received some heat wrap too to aid in keeping heat soak at bay.
Got the downpipe bolted up along with the spacer. What a bugger that was, hardly any room with a twin carb set up. Slightly concerned about room at the bulkhead, certainly won't be running trumpets any time soon, will have to chat up somebody at Demon Tweeks next Sunday in regards to filtration options.
Anywho, a pic...
As you can see, brought the strut brace out of retirement, bugger now won't clear the bonnet for some reason? :scratch:
Also fitted bits of loom, replaced nuts and bolts for stainless items and fitted my mint rear lights, pics of which tomorrow, was pitch black when I finished. Can't wait for tomorrow, really feeling the love for this car again.
coming along nicely Alex. :vcool:
Risocco
Post by Risocco »
Thank you bud, too kind :beers:
Risocco
Post by Risocco »
Today, took the rear plinth off to clean behind and fit my new plate holders. Found a previous owner decided to drill two holes in the rear panel to hold a plate on, because the 4 factory holes are not enough to work with apparently? Covered up those holes which hopefully will be the last of any water ingress into the boot.
Also finally painted the rear tow eye red, added LED number plate bulbs and fitted new number plate lamps as the old ones were beyond brittle.
Risocco wrote: and fitted my mint rear lights, pics of which tomorrow
That's how her backside looks as of today. Well chuffed.
Just waiting on parts so I can carry on under the bonnet, if it all looks as good in reality as it does in my head, I'll be super stoked :good:
Bill
Post by Bill »
Excellent work Alex, looking forward to seeing (and hearing) this sometime this year.
daveyg
Post by daveyg »
Wow, Alex, dude, that looks really nice under the bonnet. I have missed this thread it would seem. Just had a read through and its great stuff. You must be chuffed? :good:
