1986 Scirocco GT Nut & Bolt Restore OEM spec
Re: 1986 Scirocco GT
I'm having a hard time visualising where that rust is. Short term I'd grind it back and coat it until you can get a plate in. By the looks of things it's covered by the light so no-one will see it.
That looks like it's probably just surface rust and you've caught it at the right time. Get a wire brush attachment on a grinder and buff it back to bare metal, then apply a decent rust-proofer and re-paint it. Assuming it's hidden from view it'll just need a good coverage with primer and paint but won't need to look perfect.
MrFunk its behind the black rear reg surround and under the rear boot lid seal and light housing, it has some holes in it, so might need to weld em over or patch it... NOT my strong point so will need help !!
James
James
Been Cleaning up today work space was getting out of hand and needed to crack on with cleaning the arches etc...
Still need to get it cleaner but getting there now, think im going to leave the underneath as it is for now its going to be a pain in the ass to remove all old waxoly off whilst on axle stands.. So will look at that another time..
Next job is exhaust off and refurb that..
James
James
I'm sure I've asked this before but which modern tyre is most like the originals ? My current size is 185 60 14..
Took my fuel tank to a radiator repairers quoted £80 just need to find the cash..
Got new fuel hoses and paint from paints4u today to repair that boot lid and all the marks inside the boot, plus new decals for the boot area...
James
James
Back in the day VW and Pirelli were in bed together, your car was probably fitted with P6's at the factory. Evolution of that is a P6000.
Fitted 2 news ones on my Scala a couple of weeks ago, £115 all in.
It has the original rear ones on so thanks for that will order some when I'm back in work, hence all the time to work on the car..
Just a bit of info on the car:
1986 Volkswagen Scirocco GT 1.6 Auto
100% Original (although not sure on wheels)
Still has paint code sticker in boot
Still has all original hella lights
Still has all original VW Windows with car reg etched in them
Interior is like new, no rips no tears, carpet is like new
2 Previous Owners
65,232 miles
2 Previous Owners
65,232 miles
Those wheels aren't standard spec and I don't think they were a VW option either - I'm only aware of them as an Audi wheel originally.
My '86 model year GT still had the original tyres on when I bought it - these were Pirelli P6.
P6000 is the latest incarnation. P6's are also available, but are a completely different tyre to the originals and have a tread pattern that probably won't look 'right'.
The steel 16 hole wheel, part no.321 601 025H were original standard fitment to the GT from '86 onwards.
Are You really using the original tyres? Do you mean the actual 20+ yr old tyres?scratchfree wrote:It has the original rear ones on so thanks for that will order some when I'm back in work, hence all the time to work on the car..
2 Previous Owners
65,232 miles
Ha no I was saying you must be right about them having P6 on as that's whats on the rear, I'm looking to replace all 4 as the rears are old and cracking..
James
James
Grrrr
Hate things like this, really not my forte and have no links to welders, anything involving cleaning and spanners im fine...
James
James
Re: 1986 Scirocco GT Nut & Bolt Restore OEM spec
Another bad day in the office... Sometimes I think just bolt it all back on and leave it, but I just cant...
Think I will get it all back on and get some professional help for the arches next spring when i get some more funds...
James
James
- ghost123uk
Still watching your posts and progress James, excellent stuff matescratchfree wrote:Another bad day in the office... Sometimes I think just bolt it all back on and leave it, but I just cant...
That tin worm doesn't look too bad at all. A decent bodyshop would find that fairly routine compared to some !
If your not going to get it seen to just yet (and it doesn't look urgent) I would put some Vactan rust stopper on it ( LINK HERE (or at least some Kurust = next best thing). Don't be tempted to put it on thick, thin coats = better. Oh, and Vactan goes "off" in it's bottle in around 6 months
Loving what your doing to the car
