Been a while since i've posted any updates, not done too much with the car since it was MOT'd.
The downpipe developed an annoying rattle as the springs(?) up by the minifold have lost a bit of tension and the exhaust gas was making is rattle!
So, off the damned thing came so i could heat wrap it
Never actually got any pics of it being wrapped when it was off the car, looks good tho :)
The net result is the rattle has gone and inside the car and engine bay are running alot cooler! Can't reccomend wrapping the downpipe enough
The main bit of remedial work I've had to do was on the front wing - some rust bubbles had decided to appear under the paintwork
The dark spots on the top and side of the wing are where the rust was drilled out and then filled with liquid metal
If I knew the wing was this rotten I would of changed it last year for a better one!
Once it had been filled and shaped properly it was a simple case of masking the car out and re painting everything
Also re-sprayed the front bumper - I managed to knock it off its stand when i was sorting the wing out and scratched shit out of it
Looks better back in one peice tho
Since last year I've also fitted a HID kit, as i'm running the single headlight i had to go for the hi/lo H4 kit; not the cheapest of kits but makes a massive difference!
Can actually see where im going at night now
Finally, I managed to get round to spraying the engine bay to match the new paintwork!
Pain in the arse to do with the engine in the way but it looks the part now!
Think the car's done now
