Page 5 of 17
Re: Blast from the past - Marmite
Posted: Tue Aug 18, 2015 11:11 pm
by the edmundator
I thought early DX engines were solid rather than hydraulic tappets. Certainly that's what I was told about my A-plate 1.8 GTI. Not sure about Storms, or when they changed. Are you saying hydraulic because you've looked, or because you believe it to be the case?
Posted: Tue Aug 18, 2015 11:47 pm
by bengould
I "think" '84 seems to ring a bell for hydraulic tappets. Might be talking complete rubbish though.
Doubt the cam would make it sound overly tappety. I had a Kent 285 cam in my 8v and it wasn't any worse than the standard one. The first thing I would try (if your tappets are hydraulic) is a hydraulic lifter treatment additive, available for less than a tenner in Halfords*.
http://www.halfords.com/motoring-travel ... fter-350ml
Ben.
*other retailers are available (and probably cheaper)
Posted: Tue Aug 18, 2015 11:51 pm
by steve bain
I have a funny feeling it was hydraulic but I can't remember and I said dx but then started thinking about it. The original dx is long gone and its on its 3rd engine now but don't recall if I kept the head or replaced with dx or something different. I did keep the head when I put the 2e on but can't remember if its the dx one or a more recent one. I have feeling I may have upgraded it to the hydraulic. I think I will have to take a look! I understand the number of bearings define if hydro or solid. I will try the treatment too. Good plan
Posted: Tue Aug 18, 2015 11:56 pm
by steve bain
Wynns purchased off eBay. Let's see if it helps. I need to do the cambelt so will perhaps look at the head at same time. Maybe get a big valve head....
I also bought the 25mm spacers today I was after for the back.
It is all very exciting now. It's feeling close....
Posted: Wed Aug 19, 2015 8:45 am
by G Beats
We get the same with Sally we have the Scala DX Engine I think will buy some this Wynns for her.The steam seals have gone on her as she smokes a bit when you start her up. She has nearly done two hundred thousand now.Will coast a lot for our mechanic to do this job and were we live here you are not allowed to do repairs on vehicles.
A chap from vw heritage had a mk 2 that done two hundred and eighty thousand and his mum had one that a mk 2 as well that had that done three hundred and forty thousand.She has just had a brand new M.O.T on her Radiator, thermostat, thermostat housing.Getting a brand new outer boot lock seal fitted, and angel pipe fitted as this make her run better.The brakes have finally been bleed the brakes as the brake bleed nipples were seized new brake bleed nipples fitted.
Posted: Wed Aug 26, 2015 7:29 pm
by steve bain
So I stuck the wynns in tonight and it worked a treat. Everything is quiet again so fingers crossed it stays good. The car also started up first turn so very pleased.
The 25mm spacers arrived today so slapped them on. I think I need to change the 195/45 tyres for 185/45 or even 165/50as its just to close near the rear and hits. I may roll the arches a bit but not keen to after fitting new ones so I think tyres will do it. I need 4 tyres anyway and they do look a bit square!
Anyway. Pics. Hope you like even if slow progress .
Posted: Wed Aug 26, 2015 7:31 pm
by steve bain
Bit clearer on the other side
Posted: Wed Aug 26, 2015 8:20 pm
by Risocco
Hey man, terrific effort so far, look forward to more updates.
Posted: Thu Aug 27, 2015 12:53 am
by G Beats
Great bodywork repairs it is coming on.Yeah look forward to the picture updates.
Posted: Thu Aug 27, 2015 8:24 am
by steve bain
cheers guys. the filler work is very far from perfect but will give the bodyshop a base to finish off. once the wedding is done (just over a week now) and the weather gets better I will get cracking again. planning paint for early next year now as seems silly to get fresh paint just before winter when she lives outside.
Posted: Mon Apr 25, 2016 3:23 pm
by steve bain
just thought i would bump this as its now on the third page!! the weather is getting better so work is to start again soon. probably this week if the rain holds off. when i left it there was a bit more welding to do around the rear seals and passenger side cill and then off to the bodyshop. probably only a few days work really. last time i also recall that although i fitted new discs, pads, lines and fluid etc that the pedal was squidgy (but worked) so will need rebleeding and that i need an exhaust clamp.
looking forward to starting work on her again. If i don't manage to get the welding done and in the bodyshop by june i will pay the bodyshop to do the last few bits. i want to have her moted this summer
Posted: Mon Apr 25, 2016 8:21 pm
by Mr Funk
Excellent work Mr Bain.
Good to see you back
Posted: Tue Apr 26, 2016 8:45 am
by steve bain
i purchased a refill gas bottle today, so i can start this week. whoop!
also started her up last night. battery still works, engine still runs. very pleased
Posted: Fri Apr 29, 2016 9:09 am
by steve bain
so good to my word i did some work last night. I bled the brakes again (turned out the rear calipers were upside down of course!) so that was easy enough so i now have brakes. yay. i also cleaned up the rotor arm and dizzy as she was running rough, very smooth now. i will replace them when i next go past gsf.
I ground back some previous welds along the passenger cill and was pleased to see i had already welded most of the cill up making life a lot easier!
i removed the roof gutter plastic things and found only one bit of rust which i hope to be able to just treat
and compiled a list prior to paint. a very short list!
- weld in rear valence repairs (these have been tacked in but i ran out of gas last year). only a few inch square.
- repairs passenger front jacking point. this may just need rust treating but assume replace panel.
- one small repair to drivers side door shut
- finish the rear bootlid seal lip (mostly done)
- couple of small holes in passenger side footwell
- remove glass and hope for the best there is not too much rust in there!
thats it!! i can't believe i did so much last year and got so close. i need a good couple of days on it and that will all be done.
anyway, a couple of general photos, because that is all anyone really cares about!
Posted: Fri Apr 29, 2016 9:10 pm
by steve bain
I had a couple of hours tonight after work so I did a 'holts 2 stage radflush' as the coolant (or lack of) was Brown. It came up really well so just need to do the coolant. Not exciting but essential. Took ages though!
I also welded a more substancial bracket on the bonnet for the gas strut as the old one was crazy flimsey and had snapped.
good news is I went to fill in the tack welds on the rear valence and I have already done them! So just ground back.
That's it for tonight as it got dark.
