Year I was born. The Golf Gti, Star Wars, Smokey and the Bandit and Rumour by Fleetwood Mac. A fine year. Best mate was born the same day the King died.Old Mac Rocco wrote:Well I did work in Holland (1977 when Elvis died) when I was a lot younger but I think I'm too old to move now.![]()
Eating all the cookies appears to have worked again. (Can't find fat b-----d smilie).![]()
Site problems - flag them here please
Please can everybody add a town/city location at this point in your profile? Makes life much easier if you start listing parts wanted or for sale.........cheers
Re: Site problems - flag them here please
Not able to change my siggy image again, the image is within the size needed but keep getting the 'It was not possible to determine the dimensions of the image' message
sander hoogendijk
- Mr. Fixit
Nope, still getting the same error message
sander hoogendijk
- Mr. Fixit
I will look for it in a couple of days.i'll let you know
need something fixed??
Made a new thread this afternoon in "mk1 scirocco" & seems to have disappeared? it hasnt been moved either?
thanks
thanks
Noted, will look into.tobyio wrote:Made a new thread this afternoon in "mk1 scirocco" & seems to have disappeared? it hasnt been moved either?
thanks
Old Mac Rocco
Having the same or similar problems with "missing posts".
I am credited with 641 posts but when I click on "search users posts" I have only 539 so the numbers do not tally up ??????????
I only found this out when I tried to post a link on the "Headlight adjusting screws" thread and it couldn't find the link.
I would have thought both numbers should have tallied up.
Could other members compare the credited posts and the "search users posts" links to see if theirs tally up. Thank you in advance.
I know you'll come up with the answer Ian.
I think I can answer this as it's been flagged in the mod room.
It appears to be something to do with the pruning that goes on behind the scenes. Things get routinely deleted due to age (there's not enough hours in the day to shift through and save some and delete others) and that effects the post count.
I think
I think
sander hoogendijk
- Mr. Fixit
there are indeed some prune settings for:Old Mac Rocco wrote:Having the same or similar problems with "missing posts".
I know you'll come up with the answer Ian.![]()
general scirocco chat,
and selling and wanted topics.
if you post a lot in those area's your most likely to loose some posts in a while.
sander hoogendijk
- Mr. Fixit
it should be working, just tried to upload an image with size 90x83 and it worked for me.Birdy wrote:Not able to change my siggy image again, the image is within the size needed but keep getting the 'It was not possible to determine the dimensions of the image' message
if it doesn't work, check the box "delete image"
press submit, and try it again.
Still the same, the image size is 590 x 98 so under the 600 x 100 size limit
sander hoogendijk
- Mr. Fixit
sorry i'm not thinking straight... i checked the avatar and didn't checked the signature image.Birdy wrote:Still the same, the image size is 590 x 98 so under the 600 x 100 size limit
will look into it tonight.
sander hoogendijk
- Mr. Fixit
