1986 Scirocco GT Nut & Bolt Restore OEM spec
scratchfree
Re: Best way to sell a 86 Scirocco GT ??
Post by scratchfree »
Did a bit more tonight, off to powder coaters on Friday.
James
P.s Can anyone tell me if this bush looks knackered ? Or if the part is easily sourceable, VWHeritage sells one for about £60 each :shock:
It looks okay. But it'll need to come out anyway when they powder coat it and with the effort you're going through why not make the most of it?
pajsh
Post by pajsh »
Agree with Funk.
Brackets and bolts look in good condition compared to mine so bushes should be too, but not that expensive to replace so might as well do it while it's off.
And as said there going to have to come out anyway.
It's likely they've never been replaced - you may as well do the whole job properly.
scratchfree
They seem pricey for I guess one bush.
How about these http://www.superflex.co.uk/proddetail.p ... 03-1555KSS
I used them in my mk1, they can be a pain to get in as in one peice, you can get some which are split in 2.
There are loads of makes out there, Mk1 golf bushes are the same as the Sciorcco Mk2.
scratchfree
Them eBay bushes do include the metal insert! I don't like the look of them fancy bushes really doesn't go with my original look..
James
Really?
I admire your work and the effort but that's a bit of a naive attitude. No one will see it but you may well notice the difference. And if you want to keep it original go back to crappy fuel, strip all that powder coating off and fit less grippy tyres.
Original is not always best.
Unless you want a particularly firm/sporty ride, an equivalent of the standard rubber bushes will be fine; most people's experience of them these days is of crumbling, perished and squashed 20-30 year old bushes, so poly bushes are obviously an improvement, but might actually be unnecessarily harsh for normal road use.
scratchfree
Cheers Edmunator, good advice.
scratchfree
Few more updates..
James
scratchfree
Had a few days off..
Bolts etc Before:
Tank Holding Plates and Bumper Bolts before:
After:
Zinc'd Parts:
New Hardware:
Back Plates:
Original VW Grommet:
New Brake Parts, new discs were in garage being painted:
New Shoes and cable:
New Cylinders:
New Spring Kit:
Should have the rear end complete by mid next week, then its onto cleaning underneath the bodywork, then re-fit.
James
Christ on a bike.
Superb dedication. What did you use to clean all the bolts? I found vinegar just the job pretty well but nothing like that.
scratchfree
Thanks, I just send em off to a company in Rochdale, Manchester, AnoChrome leave it all to them to clean and yellow zinc plate.. £20 a time.
Wish I could afford all VW Original parts but when a cylinder is £35 from VW it was £4 from a family members brakes place http://www.brakesint.co.uk it would be silly when the parts hidden and only used for show..
James
hiltow
Post by hiltow »
Looking good - it's really satisfying once this job is done! Makes such a difference to the car getting it detailed like that.
I went through it myself a couple of years ago on my own '86 GT (axle off, blasted, repainted, new brakes, full suspension rebuild etc.). Cost a fortune, but then again I had all genuine VW parts used, right down to the last nut bolt and spring washer. Also in Rochdale by the way - we'll have to meet up next year when the sun comes out again!
