Aaah, I see it now !scratchfree wrote:Water pump!
1986 Scirocco GT Nut & Bolt Restore OEM spec
Re: Best way to sell a 86 Scirocco GT ??
Just a little update...
Lost me contact details for a good local engine mechanic so need a new one maybe... anyone want to come work on the engine (new head gasket) for a night its Rochdale Manchester... will offer money...
James
James
That red speckled braided return hose to the expansion tank will be the envy of a few people! Can't get that anywhere it seems.
Good work. If you want it all perfect, get yourself some new braided vac pipe that isn't frayed. Will be black though not that original weird colour if that matters.
Ahh didnt know the hose was so rare...
Yeah i was gonna get some new hosing wasnt a fan of the existing hose and as u can tell i like things to look new again.
James
James
Whilst the head is off and being skimmed thought I would tidy up the intake & manifold..
All complete now.. Thanks for all help along the way...
http://instagram.com/p/PPAW0LDQc5/
http://instagram.com/p/PPAkzVDQc_/
James
James
Looks good, the Audi Ronal alloys really suit the car.
Got the bug again ha...
Ok did a bit of work today... All rear drums and suspension removed along with fuel filler neck..
General Condtion before:
Brake Lines & Frame Before:
Drivers Side Arch Before:
Crud from just one side:
Fuel Filler Neck seems in good nick:
Condition of Drum and Shoes:
One Side done:
All parts will now go off to powder coaters and drums will also be faced. New shoes,springs,cylinder and new bearings and bushes where needed.. All bolts/washers etc will be sent to be yellow zinc plated..
James
One Side done:
James
Little bit of a clean this morning...
Original Un-used spare wheel:
Original Jack and strap:
Cleaned Filler Mould:
Cleaned Arch and Suspension Parts:
Hi, does anyone know the original finish on the filler neck ? Is it a satin black finish ? Or could I yellow zinc plate it to offer a better rust proofing ?
Satin black paint is the correct finish.
I fitted a brand new one to my car a few years ago now and this was the finish it came in. I gave mine a few extra coats of satin black Hammerite paint before fitting to make the finish stronger, as well as masking up and spraying the bulbous section near the top with Dinitrol wax- this is the most vulnerable part for rusting as it is welded on to the rest of the pipe and is in the firing line from debris flung up from the roadwheel.
The filler neck I bought from the VW dealer in Exeter in about 2004 was just bare metal.
Im gonna go with some VHT Chassis Epoxy Paint in Satin Black, the filler neck has VW inscribed in it, so i know its genuine so will emulate the finish it has now.
