It is. The drivers door also has a switch in it that powers the vacuum pump. The wires are quite thin, so a possible area to look when there's a fault.DJCarlos wrote:The central locking on my 1988 Scala only works off the driver's door - I thought that was just the way it is!
Central Locking
- Brunty
Re: Central Locking
Brunty
- Neillyboy
Re: Central Locking
Ditto. I had the same issue and it was corrosion on the terminals from the multiplug to the switch unit. It works every time now.
