Central Locking
Brunty
Re: Central Locking
Post by Brunty »
DJCarlos wrote:The central locking on my 1988 Scala only works off the driver's door - I thought that was just the way it is!
It is. The drivers door also has a switch in it that powers the vacuum pump. The wires are quite thin, so a possible area to look when there's a fault.
Brunty
Neillyboy
Re: Central Locking
Post by Neillyboy »
Ditto. I had the same issue and it was corrosion on the terminals from the multiplug to the switch unit. It works every time now.
