Soft brakes??
Re: Soft brakes??
ChrisPears wrote:using an eezi bleed, and the pumping the pedal method at same time does the best job.
whilst this usually does work fine (i've done it myself quite a few times) only fair to warn that you do risk damaging the seals in the master cylinder doing this. not very likely, but can happen
irishrocket
Re: Soft brakes??
Post by irishrocket »
It's a lot better now i must say still a bit of play but it is getting better!!
You can dress a pig in a suit but you cant stop it grunting
