We don't have this problem which is a good thing but many thanks for the info.roccoGTX wrote:I had this prob once in my Mk2 GTX with the temp light flashing.
I had oil going into the header tank, due to the oil cooler on top of the oil filter breaking down and mixing the oil and coolant. Also had overheating. There was no mayo under the rocker cover.
After a lot of invesigation we found the cause, but not before the oil contaminant had perished the coolant hoses.
Had to replace oil cooler, hoses, header tank and water pump and have the head skimmed as it was slightly warped.
Since then it's been fine.
I think that the oil coolers are becomin g a bit rare now.
John
Red light flashing on and off in dash instruments.
Re: Red light flashing on and off in dash instruments.
- dozzum
Like Ed said, the printed circuit boards are a common fault on the back of the clocks.
I find if you thump the dash it stops.
Sometimes it requires several hard thumps!
The joys of old cars...
Have you checked the sender unit in the expansion tank? It should look like this
http://www.ebay.co.uk/itm/VW-GOLF-MK1-M ... 336aac241a
The pins at the bottom do corrode away.
Jimmytdi
I have recently had the light flashing at random times, each time I stopped, got out, opened the bonnet to find nothing wrong (temp needle normal, rad fan kicking in and out ok).dozzum wrote:Like Ed said, the printed circuit boards are a common fault on the back of the clocks.
tried dozzem's bash the dash method and it worked! If I hit it again the red light comes back, another hit and it goes off!
'88 Jade Green GTX
When I engage the handbrake the oil light flashes.
Obviously.
True story
Obviously.
True story
I've been chasing the same problem in my 1984 recently. Sometimes the red coolant LED flashes, but gauge reading is normal, coolant level is fine and there is no overheating. The car has both a coolant level sensor in the expansion tank, and a temp sensor in the water flange on the head. The level sensor is connected to a control unit in the relay panel. The control unit and the temp sensor connect to the coolant gauge in the cluster.rustyinn wrote:Did the new parts fix it ? I've got the same problem on my 1986 GTX. Starts flashing about 5/10secs after startup, coolant level is fine and is circulation. Temp gauage never gets over hot. Just damn annoying as your driving.
Dave
If things are working properly, the red coolant LED should flash for 4 seconds when you turn on the ignition, and then go out. After that it should only flash if the car is overheating or the coolant is low.
I've checked my control unit, the level sensor itself, and the wiring. Now I'm thinking the problem is actually in the coolant gauge itself.
Assuming the Scirocco uses the same type of gauge as other VWs, the gauge has a circuit which controls the LED flash. There is an electrolytic capacitor in there, and the cap tends to go with age/use/temperature. The symptom of a failing capacitor in this case, is that sometimes the startup blink lasts longer than 4 seconds, and then eventually never stops. If this happens the gauge either needs to be replaced, or it may be possible to replace the capacitor in the gauge.
There is a good description of a very similar issue with mid-80s Vanagons on the Samba website (warning, its a long thread)
http://www.thesamba.com/vw/forum/viewto ... sc&start=0
Also, here is a link to a Vanagon website where they describe how to fix the issue by replacing the capacitor
http://www.vanagonauts.com/Warning-Light-Fix241.htm
I'm going to try swapping coolant gauges at this point and see how that goes...
Regards,
Tom
Mk2 Scirocco Storm
Mk3 Golf GTI VR6
Mk3 Golf GTI VR6
Just an update on my previous post concerning the red flashing coolant light. The quick summary is that in my case, I needed to replace the capacitor in my coolant temperature gauge to fix the constant red flashing LED problem. If you want to be bothered with the details, keep reading...
I did purchase a used cluster and swapped the coolant gauge with mine. That was a fairly stupid thing to do as I neglected to test the used cluster first, and it turned out that its coolant gauge had exactly the same problem as my original. So instead, I decided to do this properly.
"Properly" means testing the coolant gauge outside of the car. This is not hard to do if you have a basic understanding of electricity. If not, you can probably find somewhere to send the gauge for testing and repair. What's needed is a 10 Volt (9.5-10.5V) DC power source and some resistors that give you a few different values between 30 Ohms and 250 Ohms. A multimeter is also needed to confirm your values.
For a 10V power source, I used 6 flashlight batteries in a couple of battery holders chained together. I confirmed the voltage was just about 10V using a meter. I picked up six 10 Ohm resistors and two 100 Ohm resistors (rated for 1W) at the local electronics shop.
The rear of the coolant gauge has 3 screw terminals. One is smaller diameter than the others. This one should be connected to earth. The screw terminal at the top of the gauge (meaning the top one if the gauge was mounted in the cluster), is the terminal which connects to the coolant sensor. For this test we'll connect it to one side of the resistor, and then connect the other side of the resistor to earth. Finally, the last terminal (which is the terminal closest to the fuel gauge when the gauges are in the cluster) is connected to 10V.
If you're curious why 10V and not 12V, it is because the coolant and fuel gauges do not get power directly from the battery, rather via the voltage stabilizing transistor on the rear of the cluster.
According the the manual, the gauge wants to see between 40 Ohms (hot) and 258 Ohms (cold) on the signal line - that is the resistance between the signal terminal and earth. So by changing the resistors, we should be able to get the needle to move to different positions on the gauge. Note: the manual quotes settings on the VW1301 tool. Bentley has a table which shows what the 1301 settings correspond to in terms of actual resistance values here: http://www.bentleypublishers.com/tech/v ... esting.htm
The red LED should flash for a few seconds when power is first applied to the gauge, or if the coolant is really hot (30 Ohms caused the LED to flash for me). I knew my gauge was bad because whenever I'd apply power, the LED would flash constantly. (Low coolant should also cause the LED to flash, but the coolant level control unit in the fuse panel does this by making it look like an over temp condition, so it's really all the same).
The next step was to replace the 10uF capacitor as described in Vanagon link I posted previously. If you're uncomfortable with your soldering, it shouldn't be too hard to find an electronics tech who can replace the cap for you. I did it myself using a fine tip soldering iron (25W) and desoldering braid. It wasn't as bad as I thought it might be. I used the technique shown in the link of putting the new tantalum cap on the top of the board. The other option is to disassemble the gauge further and replace it on the bottom of the board, but that is more involved.
With the cap replaced, I tested the gauge again, and now the light blinked for 4-5 seconds when power was applied, or if I used a 30 ohm resistor in the signal path, simulating overheating. With the gauge reinstalled in the cluster, all seems fine now (keeping fingers crossed).
A few points worth mentioning:
- if you decide your coolant gauge is bad and want to replace it, don't just swap in another used one. At least test it first. But even if you test it, the capacitor may be on its way out. A better idea would be to just go and replace the capacitor on the gauge so you only need to do the job once.
- when testing the cooling system electrics, you really should not simply short the signal wire directly to earth to see the needle move. This causes a lot of current to flow through the gauge, and while I haven't tried it, I would not find it hard to believe this could ruin the gauge. If you want to test the gauge, grab a 30 or 40 Ohm resistor and short the signal lead to earth via the resistor instead.
- The coolant temp gauges are available from VW Classic (at least the type in my 1984 model), but they are fairly expensive.
Finally, I should mention that I found out about the capacitor issue and how to replace it by reading the very helpful posts David Beierl made on the Samba website, so a big thank you to David!
Mk2 Scirocco Storm
Mk3 Golf GTI VR6
Mk3 Golf GTI VR6
All sorted now many thanks for all your help off here it is always very appreciated.
