Our car is still in the garage a few miles away so I don't know what code my box is until Monday
Like there is a "9A" box on here for sale...
@ bensspares, what code is on the box you have for sale ? (if it matters that is ?)
Also, Question = I assume my 85 GTS will have the smaller (90mm ?) drive shafts, is it easy to swap the flanges over if I end up with a later (100mm ?) type box ?
Edit = I found this http://www.brokevw.com/020flange.html on swapping the flanges over = not a 2 minute job and it seems you need a special tool !
Edit = Another resource containing info re the differences between the various codes, including flange sizes and ratios = http://www.brokevw.com/020ratios.html
