Well over the last few weeks I’ve finally fitted the triple gauge kit, well 2/3rds of em anyway. First off getting the original lower centre console in or out without removing the seats is nearly impossible unless you cut the rear metal brace free, then it required mots of swearing and removal of virtually everything except the top dash!!!!
The voltmeter was a really easy fit, take out the fuse box connect to one of the free blade connectors on the right hand “negative” side of the box and then earth it to the round earthing block job done ;)
The next job though was much more difficult, the oil pressure gauge. I had already bought an adaptor so that I could I could retain the oil pressure warning buzzer but this was quiet big. So much so, and after several brews and “test fits” meant I had to swap round the oil temperature and pressure sensors on the engine to give me enough room to fit them. Even then it require the top of the dizzy being remove and copper washer spacers to ensure the second side connector screw thread ended up facing to the front to the front of the car so it could be used.
This all in it was tome to drill through the bulkhead, this had to be on the driver’s side as it offered more room, I carefully measure “with eye” to the passenger side of the other capillary pipe and drilled through, looked in the engine bay and for the life of me I couldn’t find the hole. Then I saw it right through the wiring loom!!!!!! A brew to calm down later I went out to see the damage, removing the outer black rap to reveal the wires, thankfully I’d only shaved a few of the wires, none were broken so I taped them up and alls working for now. Hooking up the pressure gauge was straight forward then, the only thing I need to do is get it out abit more to bleed the air out of it but all seems to be working.
Now I did say I only got 2/3rds working, the temperature gauge came pre-assembled with the sender already attached, and the addition of a fitting kit. Unfortunately the screw threads for both the oil and water temperature sensors are only 10mm, the screw thread on the sensor was over 13mm. currently its not connected so I’ll be on the lookout for a replacement. It’s a shame as the kit I got was really good value for about £55, still we live and learn. Oh and the lights are a yellow, they were hooked up to the light that originally lit up the ashtray ;)
All just needs a cleanup and some back to black
