so there you go, if your after a 256mm upgrade without hassle it's tigra caliper.
you will need the tigra flexi's and slightly longer caliper bolts.
not sure what model tigra there off though but i hope this helps
sorry i'm not sure of the make of the calipers but you could have a point about the corsa and i'm sure i read some where it was possible to fit the 16v astra gte calipers (dont quote me on that) so you could be right.Nate wrote:if memory serves, the tigra was based on the corsa platform, so the sportier late 90s corsas might also be another source of these calipers, and probably similar vintage astras may have the same.
do you know what make the calipers are?
nice one, i hope i've been a help to to people, like i say i have been wanting to upgrade mine for ages and the tigra one's bolted straight on, you just need slighty longer bolts (which i paid 2 quid for new, and the tigra flexi's as they bolt to the caliper diffrently, luckily mine came with them, i'll try to get more info and get back to you.Nate wrote:i will have to investigate. i've got a box full of old vx calipers in the shed
mk2 16v golf.ghost123uk wrote:Which disks are you using ?
