Ah yes, I was miles away..
yes you would need a Mk1 Golf/Scirocco big block gearbox, flywheel, clutch, clutch cable, gearlinkage and speedo cable
Joti's VW Scirocco Typ 53 from 78!!
Re: Joti's VW Scirocco Typ 53 from 78!!
Yes.MikeH wrote:Cool... Mk1 Golf and Mk1/2 Scirocco gearboxes are pretty much the same, btw, although being a 1.1 litre, yours probably has an 084/085 gearbox rather than the 020 type you get on the bigger engines. You may well know that already, but just to be sure.
That is what is goingo to happen.Winston wrote:Ah yes, I was miles away..
Now i'm with many doubts about installing or not Golf mk1 fender's or not.
Like this american Rocco:
They poke 1cm more than the standard ones.
What it's your opinion??
I like very much the way they fit the car, it appers they have born in there.LOL!!
I want a race look rocco, very wide and low.
So here are some updates:
Sterring box from VW Golf MK1 GTI:
Bumpers thanks to Winston:
New Wheels that you already know, Compomotive TS 3-piece (9.5x16, 5x120, ET 20+), soon to be modified to 4x100PCD and centerbore 57,1mm:
Recaro seat's from Vauxhall Ascona:
And next week, AFT block:
Well an update:
BBS RS 077:
8.0" x 16";
5x112;
Centerbore 66,56mm's(mercedes);
Offset: 35mm's.
Soon to be redrilled to 4x100, with white centers.
Compomotive TS's will be waiting for my next project for family trip's and more daily use, BMW E28 524td.
BBS RS 077:
8.0" x 16";
5x112;
Offset: 35mm's.
- G60MAT
Any updates?
Hello
Yes more uptades:
Part's donor that i recently bought:
VW Scirocco TS from 1976, as i said above for part's to my silver rocco.
And obviously more rims:
Compomotive CX400 in 4x108pcd;
- 7x15 with ET 0;
- 8x15 with ET -12mm;
Will have to redrill hubs, discs and drums to 4x108.
Another important piece to my project:
G23 Engineering Adapters 4x100 to 5x112 with 18mm thickness.
For now it's all, but i'm in love with PLS Daytona in 14", let's see how it is going to end, eheheheh!!
Yes more uptades:
- 7x15 with ET 0;
Winston
I have finally made my mind up and going for 14's... Good choice.
I'll run 15" Compommotive CX400 in 7x15 ET0 and 8x15 Et -12 with 165 50/15;Winston wrote:I have finally made my mind up and going for 14's... Good choice.
And
16" BBS RS 077 in 7x16 ET 18 and 7.5x16 ET 15 with 165 45 16;
For now.
The green rocco is already in the body shop and very soon wil be there also the silver one, to start working on them.
As for the engine will be 1.5cc or 1.6cc with 4speed gearbox.
Anyone knows wich is the best 5speed gearbox to install on the rocco with TS engine??
