Fading on Corners
1066george
Fading on Corners
Post by 1066george »
I wonder if anyone has had this problem. I am running a 16v KR engine and it keep dying on sharpish corners but picks up again immediately when the road straightens out . The fuel pumps both seem OK as it accelerates really well in a straight line and everything else is fine. Don't don't think it is ignition. Any ideas welcome.
:ire:
Brunty
Re: Fading on Corners
Post by Brunty »
Fuel tank running very low?
Dodgy electrical connection under lateral g? You can try wiggling things while engine is idling.
Brunty
ChrisPears
Post by ChrisPears »
Sounds like you need a swirl pot in the fuel system to even out the fuel supply.
1066george
Hi,
I have today to work on my problem - thanks for responses. Going to try a second earth, new fuel, check all the connections and got a new filter to add to the mix - fingers crossed and a bit of swearing should do it!
1066george
Roxylife
Post by Roxylife »
Your problem is the lift pump in the tank.
Motorsport is my passion.
1066george
Hi Roxylife,
Had a look at the in-tank pump, it primes Ok and I did replace it a year or so ago but must admit I am not entrirely happy with it. Maybe time to find a new one!
1066george
