Hi,
i'm looking to replace those plastic seals that are found where the top of the front wing meets the scuttle on a mk1 scirocco.
1) what are they called so i can look properly for them
2) does anyone know where i can get them
cheers
what are those mk1 wing seals officially called?
Re: what are those mk1 wing seals officially called?
i was sure i already replied to this. ah well.
is it the same stuff that is used on beetle wings?
Hi,
You did indeed reply to my similar thread, but I wasn't sure if it was the same stuff either. Think I've managed to source a pair now hopefully!
Many thanks for your input, any help is always welcome to me being a total novice.
cheers
Mal.
cheers
Mal.
the beetle stuff either comes in cut to length sections (expensive) or on a long roll (cheap) it's roughly P profile, the round bit is about 5mm diameter, and the flat bit that sticks down below it is about 25 - 30mm long, with notches in to go round the bolts. any chance of a pic and/or some measurements when yours turn up?
yeah ok will do, should have them mid week. i'll post some pics up.
