replaced the door today and its not lining up its about an inch to low. i lined up the door then when i tighten the bolts it just drops down into same place.
any ideas!!!! thanks jon
drivers door not lining up!!!!
Re: drivers door not lining up!!!!
bent hinges or worn hinge pins. try putting a washer between the 2 halves of the top hinge to lift the rear of the door
