can you remove front off mk1 clock to clean??
malmac
Post by malmac »
Hi, putting my mk1 scirocco back together but the clock is full of dust from prep work etc, can you remove the face to clean the inside????
Thanks.
Mal.
DT1
Re: can you remove front off mk1 clock to clean??
Post by DT1 »
Don't know if there is an easy way of doing it, this lists 3 ways of doing it:
http://www.davebarton.com/pdf/52mmfaceinstall.pdf
Maybe someone else knows a better way.
malmac
Post by malmac »
thanks for that, yeah looks like there's no magic quick fix with these, just patience and elbow grease by the sounds of it.
think i'll opt for small screw driver option.
cheers
mal.
